2WD or 4WD
Old Nov 27, 2007 | 07:25 AM
Jimmy_Boy's Avatar
Jimmy_Boy is an unknown quantity at this point
Default 2WD or 4WD
hi guys, i have a 2000 gmc jimmy
but im not quite sure if it's a 4wd or a 2wd
is there anywhere on the VIN or something that i can tell if its a 2wd or a 4wd?
thank you
Old Nov 27, 2007 | 07:35 AM
Default RE: 2WD or 4WD
Do you have buttons on your dash between the instrument cluster and the center dash vents? If not, then you have a 2wd (or slight possibility that its awd). If you do have buttons there, then you have a 4wd. The tell tale is if you have a coil spring in the front suspension or a torsion bar (search for pictures of a torsion bar suspension).
Old Nov 27, 2007 | 07:42 AM
Jimmy_Boy's Avatar
no buttons, so its probably just a 2WD
but just outta curiosity
how could you tell if its an AWD?
Old Nov 27, 2007 | 07:57 AM
The last sentence of my post. If you have a coil spring for the suspension in the front, it's 2wd, if there is a torsion bar (horizontal bar running from the lower control arm to a cross-beam located on the frame sort of under the driver's seat), you have AWD.
I'm betting you are 2wd.
Old Nov 27, 2007 | 08:44 AM
Jimmy_Boy's Avatar
so...
spring=2wd
no spring = awd?
thank you for the quick responses
swartlkk
Feb 6, 2025 09:57 PM
theclothedcreature
Lifting Tech
Jan 22, 2010 01:37 PM
jack
Aug 5, 2006 10:59 AM
fenderfree
Dec 14, 2005 09:04 PM
zero psi
Tires and Wheels
Apr 22, 2005 11:54 PM
