3 button system question
Old Nov 11, 2019 | 10:04 PM
2001ZR2's Avatar
Default 3 button system question
I had a diagnosis of a failed transfer case encoder motor. This was in response to no lights at the switch and no reaction from the TC encoder motor also the scanner was unable to communicate with it.
So now that winter is here I have an encoder motor but have been dealing with a failed fuel pump and leaking lines. I replaced the vacuum switch at the TC and refilled the TC. I noticed the vacuum lines had fluid in them. Now I have 4x4 back but here's the question I wouldn't have expected this too fix the problem so does make sense?
If so please explain it to me.
Old Nov 13, 2019 | 04:48 PM
The only thing I can think, is your switch gave out completely...
Old Nov 15, 2019 | 02:53 PM
LesMyer's Avatar
Doesn't make sense unless you replaced the ATC fuse in the underhood relay center or repaired poor connection at the TCCM at the same time that you fixed the Transfer case vacuum switch. p.s. scanner does not communicate with 3-button TCCM, only the 4-button.
Old Dec 3, 2019 | 08:31 PM
Dr. Blazer's Avatar
Dr. Blazer is on a distinguished road
The vacuum switch on the transfer case has a history of leaking fluid up into the vacuum lines. Installing the new type of switch from GM and replacing or blowing out the lines is most likely necessary.
Trb
Feb 3, 2015 09:41 PM
bugsbunny16374
Jun 8, 2014 08:03 PM
bugsbunny16374
16
May 14, 2014 07:01 AM
bansheedave
Mar 7, 2012 08:42 PM
jersey bob
Oct 31, 2011 07:54 PM
