4.3 vs 5.7
so i have a 1998 blazer 4x4 and right now im just looking for a little bit of input as far as what i should do.
right now im stuck between building up the 4.3 thats in there now with a bigger cam and completely rebuild the bottom end or getting a 5.7 conversion and just dropping one of those bad boys in there with a shift kit in the tranny.
im sure someone on here has done one or the other so any advice/opinions on either would be greatly appreciated. also if you could please let me know what i should do as far as bore, re-surfacing the heads for a higher comp. ratio, brand/specs on the cams, pistons, crank etc.
Thanks in advance =]
Mike
Mike
Here, with a simple "350" search these where my results. The link should give you results of lots of people who have done this.
Blazer Forum - Chevy Blazer Forums - Search Results
Heres search results for "cam" lots of people who have done that also, should give you everything you need
Personally I think blazers with the 350, are beasts. My buddy has an old s10 with an ls1 in it and you feel like it's going to take off like a plane cause it's so strong. It's just a lot of power for a small vehicle, but thats what we all want !
