4.3L Blazer 11.5 mpg??
Old Mar 16, 2010 | 12:42 PM
cw3849's Avatar
Banned
cw3849 is on a distinguished road
check your CAT converter i.e. I have been getting TERRIBLE mileage and while talking to a mech. today he looked at my CAT he said it was after market and because of the cost of a new one it looked too small, so he said over time it has pry plugged up. He siad before I spend the money to go have my hydro carbons checked and that would give me a better idea if I was burning too much or not enough, etc...hope this helps.
Old Mar 16, 2010 | 01:21 PM
Schrade's Avatar
Schrade is on a distinguished road
Your EVAP solenoid MIGHT be stuck in the 'PURGE' mode. A scan will show the purge cycle mode...
That means vacuum which normally draws vapor from the cannister (once in a while), is stuck open, and MIGHT be drawing all the way from the gas tank - not vapor, but fuel.
Find the line coming INTO the cannister, and pull it. See if it has fuel in it, or a STRONG fuel smell.
Old Mar 16, 2010 | 03:47 PM
4x4blazerguy's Avatar
Why the dealer. Find a good independent garage. As a rule cheaper & better work. That is my experience. I'm an old tied mechanic that can't do a lot of this stuff anymore my body doesn't work very well twisting & turning as it did in my younger days. I have a shop that does my work & the owner knows were I'm coming from & fixes only the stuff that is needed. If I have a noise or something he will listen to it & tell me what it is & if I need to do something or just live with it.
Old Mar 16, 2010 | 05:28 PM
1997 red blazer's Avatar
1997 red blazer is on a distinguished road
I would have to agree that it is the spider assembly, And It is leaking gas into the manifold and causing the POOR Fuel Economy, Smell of Gasoline and the Poor idle with the A/C on. Hope this Helps And Give us an Update as to the Fix or Repair.
Good Luck T.J
Old Mar 18, 2010 | 11:11 AM
SuperBock's Avatar
SuperBock is on a distinguished road
Try getting a new gas cap, that might help if its not a tight seal.
Old Sep 29, 2010 | 09:00 PM
Bielat16's Avatar
Bielat16 is on a distinguished road
That smell is your evap charcoal canister. Replace it and the smell will go away, and you gas millage will come back.
Old Jan 11, 2011 | 04:17 PM
Frog's Avatar
Frog is on a distinguished road
Did you ever get this resolved???
Old Jan 29, 2011 | 04:51 PM
Frankiesurf's Avatar
Frankiesurf is on a distinguished road
I would agree with the canister. Hence the EVAP code.
Old May 25, 2011 | 05:12 PM
wagonwheel1989's Avatar
wagonwheel1989 is on a distinguished road
was smelling gas just like you are on mine...turned out the nipple on the rollover valve on the front of gas tank had broke off into the hose that goes into charcoal cannister....i dropped the fuel tank and epoxied the nipple back on with hose no more smell of gas...
PubEnemy
Aug 1, 2011 08:27 AM
Paul,T.
Jan 13, 2010 02:13 PM
amkonyk
18
May 30, 2009 11:32 PM
Swblazer
Aug 22, 2008 12:02 PM
Dakota_Don
Engine & Internal
Jul 21, 2008 09:14 PM
