4 Wheel Drive Front Housing Broken
I have a 1995 S-10 Blazer, and my issue is the tabs on the front unit that the front axles go to are broke off.My question is can this unit possiblly come out of the vehicle while going down the road.
My next question is seeing the wheels are tied to this unit by what of the axles can i take the axles out and take them apart and put just the part that goes through the bearing back in to keep the bearing from blowing out.
thanks for your input
Rick
Rick
yeah you can put the end part back in and retighten it.
I am actually thinking about trying to convert it yo a 2wd if that is possible. been searching the net but havent had any luck with it.. found tons of 2wd to 4x4 conversions but not the other way around.
Rick
Rick
ok ive been reading some of these conversion threads..i dont want to do a complete conversion..what i want to do is this
remove front driveline
remove cv shafts
re-install outer yoke to keep bearings from blowing apart
i want to set the truck down some ( i have alot of body roll) how much will it lower the truck down by adjusting the torsion bars..the rear will be easy to lower down.
thanks for any input
Rick
remove cv shafts
Rick
You've got the right idea to make it 2WD but, DON'T fool with the torsion bars. They are for adjusting front chassis ride height. If it's out of spec you can expect rapid wear of suspension and steering linkage parts.
so how would i go about doing this..all my front end parts are new..complete all the way through..drop spindles??? a-arms??? just wanting to know the best way to do it.. thanks for your input
Rick
Rick
Check this thread, there's some good info in it: Lowering Tech - Blazer Forum - Chevy Blazer Forums
Just remember, if chassis ride height is out of spec, you will have problems.
Rick
jonwilliams
14
11-10-2021 09:05 PM
mirrorimij
06-08-2019 03:34 PM
lizzj70
06-23-2010 06:57 PM
