4 wheel drive is not working
Old Dec 2, 2016 | 08:08 AM
LesMyer's Avatar
Instead of guessing, read these. Study them carefully and then ask any questions that you might have.
You have a 3-button NV233 system. It's operation/diagnosis is different than the 4-button NV236. Don't confuse them.
https://blazerforum.com/forum/tech-a...ill-help-7180/
https://blazerforum.com/forum/tech-a...gnostics-7683/
https://blazerforum.com/forum/2nd-ge...-blazer-89670/
Best wishes for a successful repair
Old Dec 11, 2016 | 06:16 PM
Nathan Brumitt's Avatar
Nathan Brumitt is on a distinguished road
So I got my 4 wheel drive to engage but the front tires still don't spin. Any ideas?
Old Dec 11, 2016 | 06:37 PM
Strangerock's Avatar
Strangerock is on a distinguished road
You say you got the 4 wheel drive to engage....Is the Tcase driving the front drive shaft ?
Old Dec 11, 2016 | 08:49 PM
What I think it might be is either the T-case switch and or a vaccum leak
Old Dec 12, 2016 | 09:09 AM
okaussie's Avatar
okaussie is on a distinguished road
If you think it is the t case vacuum switch, you can always pull the cable manually and see it the right front wheel locks. If it does, the problem is on the vacuum side of the 4wd system, if it does not, it could be the front axle disconnect system has a stripped gear or the drive gear from the diff to the front axle disconnect.
hopefully yours is simple. Mine is the front axle disconnect that is the problem and I will be rebuilding it shortly.
Good luck//
mirrorimij
Jun 8, 2019 03:34 PM
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
lizzj70
Jun 23, 2010 06:57 PM
Idriveachevy
Dec 10, 2007 11:32 PM
07g5gt
Sep 4, 2007 05:47 PM
