4 wire plug on tccm.....
Old Aug 2, 2010 | 09:20 PM
Billy_Mac's Avatar
Billy_Mac is on a distinguished road
Question 4 wire plug on tccm.....
On 99 s Blazer with nv236 auto trans 4 button dash switch.
is this pair of four wires used to power tccm and encode motor ?
Thanks: BillyMac
Old Aug 2, 2010 | 11:38 PM
These wires are the main power (orange), ground (black), and then the motor feed A & B (red & black again). Only the red & black ones go to the encoder motor. The encoder (position sensor) itself is powered off of the light green / black wire which feeds a +8V reference out to the encoder.
Old Aug 16, 2010 | 10:58 PM
Billy_Mac's Avatar
Many Thanks swartlkk.
Main power (orange), ground (black) tyed to front passenger power window
with TCCM removed window works with master driver switch only
Thanks: Billy Mac
Old Aug 16, 2010 | 11:38 PM
I guess I am not following you here... What is the problem that you are trying to solve?
Old Aug 17, 2010 | 12:21 AM
Billy_Mac's Avatar
Well copy past didn't work sorry..
Bad tccm by means of water dripping on it took out two weather pack terminals (they should be) , ruined orange main power feed to tccm. (no leak found anywhere)
Noticed with tccm removed right front power window would not work @ switch on that side only master switch driver side would bring window up or down. looking @ wiring diagram don't show that window is tyed to power for tccm....Hmmmmm.
Thanks: Billy Mac
(Grammer edit)
Old Aug 17, 2010 | 12:27 AM
There should be no connection between the power windows and the TCCM... That is quite odd.
As far as the corrosion on the terminals, the connections on the TCCM are far from weather pack connections. There is no seal on them. And I have seen corroded pins on otherwise perfectly dry components with no signs of leaks anywhere.
Old Feb 3, 2022 | 08:17 AM
Phil Manwarren's Avatar
Phil Manwarren is on a distinguished road
is there a way to test these wires ?
Old Feb 3, 2022 | 12:14 PM
GeorgeLG's Avatar
Get them disconnected at both ends then measure resistance and check for shorts to ground and power.
George
futuredoc
Oct 7, 2024 06:14 PM
Tinted
Nov 29, 2011 02:06 PM
dbcookee
Oct 10, 2011 06:49 AM
bubba181x1
Mar 12, 2008 02:05 AM
boulonman
Mar 5, 2007 05:10 AM
