4wd?
Old May 25, 2010 | 08:11 PM
Survivor's Avatar
Survivor is on a distinguished road
Default 4wd?
How exactly does the blazer's autotrac 4wd system work? Im use to the locking hubs. Also should my front drive shaft be spinning when 4wd is not engaged?
Old May 25, 2010 | 10:25 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
The 4wd works by engaging the transfer case in the proper range and engaging the front axle with a vacuum actuator. On the front axle the left driveshaft is always connected to the differential and the right driveshaft is engaged/disengaged, so your front driveshaft is always turning when you're moving. When in Auto the front axle is engaged and the transfer case is in 2WD mode, if it senses a speed difference between the front and rear axle it will briefly shift the transfer case in 4WD mode (up to several seconds if it still senses slippage). There's a clutch pack so it doesn't grind the transfer case in Auto mode. When you change the fluid you use the factory GM Autotrack fluid, there is no substitute.
Old May 25, 2010 | 11:35 PM
97MikeBlaze's Avatar
97MikeBlaze is on a distinguished road
well iiiiiii learned something today!
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
1badblaze
Sep 29, 2008 05:50 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
