4wd
Old Jan 4, 2011 | 06:49 PM
pappy247's Avatar
pappy247 is on a distinguished road
Default 4wd
hi all. inm new to this site so im hoping to find some help. I have a 1997 blazer zr2. Ive replaced the vacum accuater with a pull cable and that fixed my problem. now im having another issue, every time i push the 4wd button 4hi or 4lo i hear the tccm clicking, ive replaced the trasfercase moter with 2 differ. used ones and still wont work. can anyone help with my problem?
Old Jan 4, 2011 | 08:53 PM
Carefully unplug the TCCM and check for corrosion on the pins... it's a known issue.
Old Jan 4, 2011 | 09:18 PM
pappy247's Avatar
Default 4wd
where is the tccm located? is it hard to get to?
Old Jan 5, 2011 | 07:52 AM
dre's Avatar
dre
dre is on a distinguished road
The TCCM is behind the RH kick panel.. Does any one make a kit to go to a manual floor Shifter? i just what to be able to use the 4x4 when needed. Good luck with yours.. I had bad wires on my TCCM. if you have to put a new plug on yours be careful and only do one wire at a time. there are 3 green with blk stripes and 3 Blk with stripes.
Old Jan 5, 2011 | 05:10 PM
pappy247's Avatar
well im in the prosses of gathering parts to make a convertion to manual shift. let me know if you find a convertion kit. thanks for the help.
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
1badblaze
Sep 29, 2008 05:50 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
