4wd actuator
It is a combination of a bad vacuum switch on the transfer case and a bad input seal on the transfer case. Check the fluid level in the transfer case by removing the upper plug. If fluid pours out, you need to remove the transfer case and replace the input seal. While it is out, replace the vacuum switch.
You then need to clean out the vacuum system, hoping that the transmission fluid has not gotten all the way to the HVAC controls.
extreme
Jan 5, 2010 07:29 AM
stormshadow1
Jan 4, 2010 11:03 AM
markrd
May 8, 2009 01:39 PM
