1st to 2nd gear slip when warm, 98 4wd.
Old Oct 5, 2007 | 06:22 AM
fiszot's Avatar
fiszot is an unknown quantity at this point
Default 1st to 2nd gear slip when warm, 98 4wd.
Having a gear slip from 1st to 2nd after she heats up, more on hot days, less on cold. 150k miles don't think trans fluid was ever changed. Shall I change and re-filter? Fluid appears slightly burnt and thin.
Thanks for the info!
Glenn
Old Oct 5, 2007 | 07:02 AM
Default RE: 1st to 2nd gear slip when warm, 98 4wd.
I would atleast drop the pan and put a new filter in. You may have to drop the pan and reinstall it, then fill the trans back up with fluid. Run it for a bit to circulate the new fluid, then repeat, replacing the filter once the fluid looks good. You should be able to get away with only dropping the pan twice. Or, when you have the pan off, install a drain plug. Makes subsequent transmission fluid changes much faster!
Old Nov 6, 2008 | 03:27 PM
jesse sanders's Avatar
jesse sanders is an unknown quantity at this point
I have 01 blazer 4x4 with 150k and it appears the tranny fluid had never been changed so i went ahead and drained it against the warnings of others. before the fluid change 1st-2nd shifted odd. now it has a serious slip from 1st-2nd. the fluid is up to the hot mark on the dip stick. any advice or guidence?? thanks in advance
Old Nov 6, 2008 | 04:29 PM
Start saving.
Old Nov 6, 2008 | 07:32 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
classic! jp
Old Nov 10, 2008 | 06:03 PM
AJBert's Avatar
Install a TransGo shift kit for the 4L60E, should solve your problem before you need to do a rebuild.
bobby099
Dec 22, 2018 09:41 PM
cbrinkley83
Jun 24, 2015 08:21 PM
Daryllee
Mar 21, 2015 11:08 AM
Mattato1
Mar 7, 2012 11:05 AM
fun2b1
Apr 5, 2008 08:43 AM
