4wd help!
Old Feb 23, 2008 | 09:50 AM
chrisac85's Avatar
chrisac85 is an unknown quantity at this point
Default 4wd help!
Im very confused with my 4wd. I have a 1998 blazer with pushbutton 4x4. Everything seems to work, The 4hi and 4 low lights come on, and it sounds like the transfer case switches, no service 4x4 light. Yet it doesnt seem like the front axel is driving. I parked the truck on a sheet of ice, put it in 4 hi, and gassed it, but the front wheels dont spin, while the rear wheels just burnout. Any thoughts?
Old Feb 23, 2008 | 10:24 AM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: 4wd help!
i dont have a 4wd ,but is the driveshaft def hooked up to the truck .. have someone lay on the ground near the truck dont run them over have them look to see if the shaft is turning when you start to roll or put the truck up on jackstands and see what happens..maybe sumthing let go in your transfer case..I`m only giving thoughts since i dont own a 4wd but just tryin to give 2 cents
Old Feb 23, 2008 | 10:48 AM
*Moving to 2nd Gen Tech*
Sounds like the classic front axle vacuum actuator problem. This can be caused by a number of things. Faulty vacuum switch on the transfer case, broken vacuum line between the TC and the actuator, faulty actuator, or a seized actuator cable rounds out the problem areas. The vacuum actuator is located under the battery. So you'll need to verify that when the 4wd is engaged, that you have vacuum to the actuator.
Old Feb 24, 2008 | 09:32 PM
Johnkoch's Avatar
Johnkoch is an unknown quantity at this point
this is the same thing happening with mine
Old Feb 26, 2008 | 11:30 PM
bulldog3280's Avatar
bulldog3280 is an unknown quantity at this point
I think you may need the accuator that engages the trasfer case
Old Mar 7, 2008 | 05:43 PM
toofancy83's Avatar
toofancy83 is an unknown quantity at this point
I have the same problem! I followed my vacuum line from my actuator only to find it its broke in half and I cant find out what It hooks up to. Can somebody please help me.
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
1badblaze
Sep 29, 2008 05:50 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
