4wd is a pain help please
Old Jan 12, 2011 | 08:29 PM
If you have the 3-button switch, you may be able to remove the encoder motor and then move the encoder and verify that the channel output is proper per the information found in the Tech Article post originally created by error_401. You also should be able to rotate the motor portion using a 1/2" ratchet. If you feel any spots where the motor doesn't spin when you move the output, the gear inside likely looks like this:
von scott
Tires and Wheels
Jun 2, 2010 08:47 PM
raiders09
Jan 31, 2010 12:43 AM
BlackBlaze
May 6, 2007 11:33 AM
kornphlake
Dec 18, 2006 02:18 AM
wvpurplejimmygirl
Dec 13, 2005 05:32 PM
