4WD Problem
Old Sep 4, 2008 | 05:03 PM
Sharsky7's Avatar
Sharsky7 is an unknown quantity at this point
Default 4WD Problem
I have a 2002 Chevy Blazer ZR-2. 4.3L Auto with Auto 4WD, 2HI, 4HI, 4LO. I tried to put it into 4HI and it just blinks, doesnt engage. Same with AUTO 4WD. Then I tried 4LO. It blinked then turned into solid color, indicating that it was engaged. And it was. Then I tried to put it back into 2HI. It took sometime but it finally did. I have never had problems up until now. Any ideas?
Old Sep 4, 2008 | 07:52 PM
Default RE: 4WD Problem
The difficulty with the Auto4wd transfer case controls is that they are complex and not easily diagnosed. You need a Tech2 (dealer) or equivalent bi-directional scan tool to access the TCCM and run tests.
More often than not, the cause is corrosion on the electrical connections on the TCCM (located behind the passenger side kick panel). Sometimes, the fault is in the encoder motor and replacing it fixes the problem.
Old Sep 4, 2008 | 07:56 PM
dBsound's Avatar
dBsound is an unknown quantity at this point
Where is the encoder motor? Also behind the kick panel?
Old Sep 4, 2008 | 07:57 PM
No, the encoder motor is located on the transfer case. It is quite expensive so you will want to make sure that it is the problem.
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
waterskier98
Mar 4, 2009 03:15 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
