4WD question
Old Aug 9, 2009 | 07:32 PM
whoareyou4's Avatar
whoareyou4 is on a distinguished road
Default 4WD question
I have a 98 Blazer 4.3 vin W LT with a 3 button 4WD switch.
My Blazer is stuck in 4Hi when I push the 2Hi button it just blinks a few times then stops and it stay in 4Hi. Same thing when I select 4Lo
I hear what I think is a motor or switch or something under or near the glove box click.
Do you guys have any suggestions?
Do I have a solenoid on the fire wall? Is there a vacum line that goes to the actuator under the battery, I done see one.
Thanks for any help.
Don
Old Aug 9, 2009 | 08:09 PM
*2000ZR2*'s Avatar
*2000ZR2* is on a distinguished road
It sounds like the encoder motor on your transfer case is stuck. Happened on mine when I was in 4-lo a couple years ago. That click that you hear is the transfer case control module. Mine is located behind the kick panel on the passenger side.
Old Aug 9, 2009 | 08:31 PM
If you have the 3-button switch, you will not have the electric vacuum solenoid on the firewall. You will have the mechanical switch for the vacuum on the transfer case.
Have a look at the articles in the Tech Article (DIY) section for a few articles on the NP233/NV233 transfer cases.
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
1badblaze
Sep 29, 2008 05:50 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
