-   -   4WD question (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/4wd-question-33464/)
whoareyou4 Aug 9, 2009 07:32 PM
4WD question
I have a 98 Blazer 4.3 vin W LT with a 3 button 4WD switch.
My Blazer is stuck in 4Hi when I push the 2Hi button it just blinks a few times then stops and it stay in 4Hi. Same thing when I select 4Lo
I hear what I think is a motor or switch or something under or near the glove box click.
Do you guys have any suggestions?
Do I have a solenoid on the fire wall? Is there a vacum line that goes to the actuator under the battery, I done see one.
Thanks for any help.
Don
*2000ZR2* Aug 9, 2009 08:09 PM
It sounds like the encoder motor on your transfer case is stuck. Happened on mine when I was in 4-lo a couple years ago. That click that you hear is the transfer case control module. Mine is located behind the kick panel on the passenger side.
swartlkk Aug 9, 2009 08:31 PM
If you have the 3-button switch, you will not have the electric vacuum solenoid on the firewall. You will have the mechanical switch for the vacuum on the transfer case.
Have a look at the articles in the Tech Article (DIY) section for a few articles on the NP233/NV233 transfer cases.
