4wd service light
Old Jan 21, 2006 | 01:08 AM
99whiteblazer's Avatar
99whiteblazer is an unknown quantity at this point
Default 4wd service light
Driving home tonight and all of a sudden the 4wd service light came on. It came on while i was in four wheel drive. I tried to put it back into 2 wheel drive but would not let me. When i got home i turned the truck off to see if anything would change and now i'm in two wheel drive but the two wheel drive light is not on and won't do anything when i hit the buttons. I haven't gotten the truck scanned yet i will tommarrow but was wondering if anyone has any ideas. I just bought this truck and my firt 4wd vechicle so any help would be appreciated.
thanks
Old Jan 21, 2006 | 03:43 PM
Default RE: 4wd service light
Which statement most closely represents your symptoms:
[ol][*]Transfer Case Will Not Complete a Mode or Range Shift[*]Transfer Case Shift Control Switch Inoperative or 4 Low Indicator Stuck On[*]Transfer Case Shift Control Switch Indicator Always On - Two or More[*]Transfer Case Shift Control Switch Indicator Inoperative - One or More[*]Transfer Case Shift Control Switch Indicator Flashes and Returns to Original Mode [/ol]
Also,
Diagnostic Trouble Code (DTC) Displaying:
The transfer case shift control module is equipped with the ability to store diagnostic information, which is useful to a technician in the event of module, component or wiring failures. This information can be retrieved from the transfer case shift control module by way of flash codes, which are displayed on the three transfer case shift control switch buttons. These buttons are located on the instrument panel to the right of the steering wheel Before obtaining DTCs, perform the following transfer case control module (TCCM) Self-Test.
TCCM Self-Test
1. Observe the transfer case shift control switch indicators while turning the ignition switch to RUN. A properly operating system will flash all indicators and then will return to the current gear. If the system is operating normally, then proceed to Displaying Codes.
2. If the TCCM failed the Self-Test, then test the following circuits.
* Battery Positive Voltage (40 and 1640), and Ignition 3 Voltage for battery voltage
* Ground Circuit for ground
* Diagnostic enable circuit for an open or high resistance
* Transfer case shift control switch connector
3. If the above circuits are normal but the TCCM still fails the Self-Test, replace the TCCM. Refer to Transfer Case Shift Control Module Replacement .
DTC Displaying
1. Turn OFF the ignition for 10 seconds.
2. Connect PIN 13 on the data link cable (DLC) to a ground. The DLC is located in the cab under the instrument panel on the driver's side.
3. Turn ON the ignition, with the engine OFF.
4. Observe the transfer case shift control switch select buttons for flashing codes. Refer to Diagnostic Trouble Code (DTC) List .
Important
If the transfer case shift control switch buttons all blink only once and then stop, no fault codes are stored in the transfer case shift control module.
* When one DTC is stored in memory, that code will blink that number of times followed by a 3 second pause and then repeat.
* If more than one code is stored, the first code will blink, followed by a 3 second pause and then the second code will blink.
* This sequence will continue until PIN 13 on the DLC is no longer grounded.
* If the TCCM will not communicate the presence or absence of DTCs, test the above circuits in Self-Test Step 2. If the circuits are complete, then replace the TCCM. Refer to Transfer Case Shift Control Module Replacement .
parks336
Dec 1, 2023 12:34 PM
Geir
Oct 9, 2011 08:51 PM
2001 ZR2
Jan 16, 2010 12:39 PM
trwolf
28
Mar 4, 2008 06:59 PM
drumzandrekkids
Feb 10, 2006 11:24 PM
