4WD Vacuum Hose Question
Old Sep 25, 2016 | 04:14 PM
bgood1208's Avatar
bgood1208 is on a distinguished road
Default 4WD Vacuum Hose Question
On my 2001 Blazer, was checking/replacing the vacuum hoses for the 4WD and this one on the driver's side coming off the T was not connected to anything. I've looked and cannot find a termination point for it. Any insight would be appreciated.
Attached Thumbnails 4WD Vacuum Hose Question-fullsizerender-18-.jpg   4WD Vacuum Hose Question-fullsizerender-20-.jpg
Old Sep 25, 2016 | 04:22 PM
vadatara2's Avatar
vadatara2 is an unknown quantity at this point
Probably goes to canister located in the fender well. Look for a small nipple sticking out behind the ABS unit.
Old Sep 25, 2016 | 04:37 PM
rockp2's Avatar
Vad is correct. You'll probably need a mirror to actually see it. It's between the cruise control box and ABS, closer to the ABS (next to it) about 3" below the level of that ABS black cap.
Old Sep 25, 2016 | 05:02 PM
bgood1208's Avatar
Thanks Vad....no luck. I looked (and looked & felt around) and no sign of one. Not sure my '01 has that canister in the fender well.
Old Sep 25, 2016 | 05:03 PM
bgood1208's Avatar
Thanks Rock....the cruise control box is the Delphi box mounted to the firewall, correct ?
I'll go have another look.
Old Sep 25, 2016 | 05:37 PM
rockp2's Avatar
Correct on cruise control. It's there. Right underneath ABS bracket
Old Sep 25, 2016 | 08:58 PM
bgood1208's Avatar
Found it ! Vad and rockp2 THANK YOU !! rockp2 the pic you sent and suggestion to use a mirror were priceless. Thanks again gentlemen...I appreciate your time and expertise !
Bill
Old Oct 1, 2016 | 12:42 PM
bgood1208's Avatar
Here's a video that I stumbled across that also shows location:
Blazonaire
Dec 23, 2015 02:03 PM
GunsOfNavarone
Jan 17, 2011 01:06 PM
rob1621
Apr 3, 2008 08:55 PM
fzr confused
Apr 1, 2006 03:06 AM
fzr confused
Mar 30, 2006 12:38 AM
