4WD Vacuum Line and Reservoir
Old Jan 17, 2020 | 12:47 AM
Americannoli's Avatar
Americannoli is on a distinguished road
Default 4WD Vacuum Line and Reservoir
Hey I've got a 1996 Chevy Blazer LT with the three button 4WD switch. I've recently tapped new holes into the skid plates and decided to change out the Vaccum actuator, and Transfer Case Switch. After doing so the car seemed to use 4WD when engaged but recently stopped. I popped the hood and greased the cable that connects into the vaccum actuator. I was wondering how hard it was to replace it and how to do so. Secondly, the vacuum reservoir (black ball) that mounts to the bottom of the hood has broken off. I was wondering if someone could link me the proper parts for the Vacuum Reservoir, Vaccum Reservoir Vaccum Line, and the T intersection it connects into as well as a new cable for my actuator. I'm hoping it's not hard to remove and replace. One of these days I'll get a posi lock.
Old Jan 17, 2020 | 08:23 AM
LesMyer's Avatar
Since the front axle lock in works on vacuum, I would fix the vacuum reserve tank first and then see if the 4WD works. Junkyard for the vacuum reserve tank - you aren't going to find a new one. Any GM dealer or the Internet should be able to easily provide a P/N for the actuator cable. Good luck.
dwmlr
Dec 10, 2015 07:39 PM
Miket919
Jan 21, 2012 12:57 PM
j2ther
20
Mar 12, 2011 06:38 PM
GunsOfNavarone
Jan 17, 2011 01:06 PM
speedfreak81
Feb 4, 2010 10:10 PM
