4x4 but not
Old Feb 13, 2011 | 03:47 PM
blazer&camaro's Avatar
blazer&camaro is on a distinguished road
Default 4x4 but not
hey guys couldn't find any problems like my truck so here it go's.
Blazer won't come out of 2hi. I can hear the motor engage both 4hi and 4lo both have solid light saying it works. New actuator and i have vacuum to it and new light drive switch. I can pull on the actuator cable but no sounds from the differential. need fixed this is the only thing wrong on my truck. thanks
Old Feb 13, 2011 | 07:05 PM
UberFail's Avatar
UberFail is on a distinguished road
Welcome to the forum first off! secondly can we get MORE info regarding your blazer as the 4x4 system changed a few times during the run of this platform.
how far does the cable travel when you pull on it? is the actuator pulling on the cable while its in 2hi? what kind of sound do you hear when its attempting to engage 4x4 ??
Old Feb 13, 2011 | 07:58 PM
It is a 1997 blazer with a 4.3 automatic 4 door 3 button. Need any other info just ask. I could only move the cable when the truck is off butt only 3/4 to an 1.
Old Feb 13, 2011 | 08:47 PM
UberFail's Avatar
ok so when its on that cable is pulled then? if so chances are the transfer case switch (vacuum switch) is likely pooched - SAME boat i'm in at this moment but i know my actuator is constantly pulling on the cable in 2hi.
normal movement of the cable is like around 1/2"-1" max so ur in the right movement range at least! btw... should check into this also! 4x4 No Worky.... Maybe this will help.... - https://blazerforum.com/forum/tech-articles-diy-29/4x4-no-worky-maybe-will-help-7180/
then you can do the OBD2 NV233 Diagnostics - https://blazerforum.com/forum/showthread.php?t=7683 - to see if you have any error codes stored in the TCCM on your ride.
Old Feb 14, 2011 | 08:20 AM
Same here my new actuator is in high all the time. I forgot about the switch on the transfer case. I will look at that next. I uselly work on camaros and firebirds 4 wheel drive is new for me.
Old Feb 15, 2011 | 02:26 AM
gregl316's Avatar
gregl316 is on a distinguished road
Default vacuum lines
Don't go buying anything till you check the hoses. I thought it had to be my switch on the xfer case. I replaced it only to find out it was the vacuum line from the xfer case switch to the actuator had 2 holes wore in it above the trans. That was a spend y piece of vacuum line. Don't overlook anything.
Old Feb 16, 2011 | 02:24 PM
it deffenitly has vacuum the actuator is sucked up tight and there appears to have no holes in the lines. my luck it will need a front diff.
Martin13
Nov 15, 2013 07:32 AM
hawk45
Dec 18, 2010 10:08 PM
stschuyler25
Nov 21, 2010 09:34 AM
redblzr4x4
Jul 14, 2009 02:10 PM
gewebb
Dec 19, 2007 10:36 AM
