4x4 and dash switch Lights not working
Old Sep 25, 2018 | 07:59 PM
  #41
gojimmygo111's Avatar
gojimmygo111 is on a distinguished road
Do they just pull out? From the top or bottom? They are such small pins that it sounds like a tedious job. My eyes are not so good anymore...LOL
Old Sep 26, 2018 | 11:05 AM
  #42
LesMyer's Avatar
The terminals pull out the back of the connector as soon as you trip the release. Yeah, it's pretty tedious. Look at the photo of the terminal in the Amazon ad. There is a metal strip on the terminal that snaps into the terminal and catches, preventing the terminal from backing out. Usually inserting a paper clip along side the terminal in the back of the connector will bend the catch back and release the terminal. If you look into the hole in the back of the connector where the terminal is, you can usually see where the catch is located. Easy does it. If a metal strip on a terminal gets permanently bent in too far to catch and be retained securely, you can gently pull it back out into place with a dental pick.
Old Sep 26, 2018 | 11:38 AM
  #43
I seem to recall having to remove a plastic comb like retainer plate before getting to the terminal with a
terminal removal tool terminal removal tool
Old Sep 26, 2018 | 01:30 PM
  #44
LesMyer's Avatar
Originally Posted by swartlkk
I seem to recall having to remove a plastic comb like retainer plate before getting to the terminal with a terminal removal tool.
Probably you are correct.
Old Oct 21, 2018 | 08:58 PM
  #45
ak3394's Avatar
ak3394 is on a distinguished road
Originally Posted by chevyriders
You can get new switches for under 20 bucks. Check amazon, or Wal-Mart as graveyard said. If you can't find one for 20 bucks (which I'm positive you can if you're in the U.S.) I'll send you one of mine for 20$. Not sure on the testing procedure for tccm.
do do you still have yours that I can buy?
pifer5286
Mar 3, 2023 09:44 PM
Flyfishen
Sep 19, 2016 11:07 AM
Jacob Bo
May 3, 2015 12:41 PM
Jimmybeatergal
Nov 26, 2013 02:27 PM
spanner
Sep 2, 2011 01:21 PM
