4x4 help!
Old Oct 14, 2011 | 09:00 PM
dbcookee's Avatar
dbcookee is on a distinguished road
Default 4x4 help!
no 4x4 in my 2000 chev blazer
tcase motor replaced,
tccm flashed, replaced
wire from tccm to tcase new,
4x4 switch in dash new
i had to re-wire the plug for the tccm due to water/corrosion damage.
transfer case shifts and locks into 4hi, 4low, and 2wd no problem.
rear axle locks up like it should,
but NOTHING from front axle.
doesnt even try to engage,
any help would be appriciated, im not sure of what to look at next,
thanks guys!
Old Oct 14, 2011 | 09:08 PM
xgiovannix12's Avatar
read this over it should help you
https://blazerforum.com/forum/tech-a...ill-help-7180/
your front axle isnt engaging it can be a vac leak or the cable going to the front axle
Old Oct 14, 2011 | 11:15 PM
Mike98Blazer's Avatar
^^^ what he said.
Old Oct 15, 2011 | 02:10 PM
dbcookee's Avatar
thanks guys!
Old Oct 15, 2011 | 04:05 PM
caddylac's Avatar
caddylac is an unknown quantity at this point
thanks guys!
Hey man I just went through the same thing with my 98 blazer. I replaced the actuator under the battery tray, which it wasnt bad. Ended up being a transfer case switch which was 10.99 | O'Reilly Auto Parts Mine was doing the same exact thing as yours
Old Oct 15, 2011 | 06:09 PM
dbcookee's Avatar
what do you mean transfer case switch? the indash buttons? or on the t case itself?
Old Oct 15, 2011 | 06:11 PM
theres a switch on your transfer case that lets it select 4hi 4lo or 2wd
your transfer case locks into these options
your problem is the front end isnt engaging
did you check the vac line under the battery ? what about the Actuator or the cable ?
this thread shows you how to check and test these things
Old Oct 15, 2011 | 07:07 PM
dbcookee's Avatar
yeah man, i read that forum, i didnt get a chance today, cause its been pouring rain all day, and blazer with the lift, wont fit in my garage,
so im gunna start trouble shooting more tomorrow if weather holds out
Old Oct 15, 2011 | 07:22 PM
caddylac's Avatar
Yeah crawl under the drivers side and its on the top but you can still see it with some maneuvering and a light. I think it's a 7/8-22mm to take it off. I'd start there since it's only 10.99
Old Oct 15, 2011 | 07:33 PM
its a 7/8s but pulling the cable from uptop with a vise grip and trying to drive the truck to see if the fronts engaged works way better
a way to see if its engaged is when your in 4 low do a sharp turn youll feel a jumping feeling in the steering wheel
OR you could jack up the whole truck with all 4 wheels off the floor
I did both at that time
