4x4 hi will not engage, but lo does
Old Dec 14, 2007 | 10:34 PM
gewebb's Avatar
gewebb is an unknown quantity at this point
Default 4x4 hi will not engage, but lo does
I have been reading all the 4x4 post, but nothing seems to help my problem. I just want to know more before I start spending money.
99 4door
4wd hi flashes then goes back to 2wd
Auto 4wd flashes then goes back to 2wd
I can put it in 4wd lo and neutral
before i crawl under the truck in the snow (or take it to the dealer)
Are there seperat vacuum lines for hi and lo?
If it goes into low, then why not high?
any help would be great,
Industrial Maintenance Tech
with little knowlegde of trucks
G. Webb
Old Dec 15, 2007 | 07:32 AM
Default RE: 4x4 hi will not engage, but lo does
This sounds like either a TCCM issue or the encoder motor. I would first remove the TCCM (behind the passenger side kick panel) and clean the electrical connection. Also, pull out the switch in the dash and clean the connections into that.
When it goes into 4LO, have you confirmed that the front axle is engaged? Is your 'Service 4wd' light illuminated?
Old Dec 15, 2007 | 10:06 AM
gewebb's Avatar
I assume that it is engaged.The body of the truck shifts as it engages and I am limited to how fast i can go.
I will check the connections and post what i find.
thanks
Old Dec 16, 2007 | 09:27 PM
spitdoggy's Avatar
spitdoggy is an unknown quantity at this point
i dont mean to steal a thread here but i have the exact issue here with my 2000 blazer,coming home in the snow today i tried to get it into 4wh hi,no go,stopped put it nuetral,i could get 4wh lo but no hi,light blinks and goes back to 2 wh hi,yes 4 wh lo was working fine,easy to tell in 6" of snow.no warning of any kind showing.will follow thread,thanks
Old Dec 17, 2007 | 08:02 AM
To gewebb,
When in 4LO, does the front axle spin when you punch it on slick surfaces? If not, then check your front axle engagement vacuum actuator for proper operation. Most of the time, this will not cause it to not engage in 4HI or Auto4wd. I am thinking this is an encoder motor problem, but you really should have it properly diagnosed by pulling the TCCM codes (Tech2 scanner or equivalent).
To spitdoggy,
Again, this sounds like an encoder motor problem. If you do not have the Auto4wd option (you'd know if you did), then you can run through the DIY article on OBD2 Non-Automatic Transfer Case Diagnostics.
Old Dec 17, 2007 | 09:55 PM
spitdoggy's Avatar
thank you,will work on finding a bud with a scanner.
Old Dec 17, 2007 | 11:33 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
I had a similar issue. There's a solenoid in the engine bay that caused my problems. I pushed the 4hi button, then pulled both lines off of the solenoid, and hooked the "to engine" line up to the other outlet of the solenoid... it cleared it out and it worked again.
Pics:
Old Dec 18, 2007 | 10:08 PM
spitdoggy's Avatar
wow,great picts,thanks for this,i assume you switched the hose with the truck running?
Old Dec 19, 2007 | 10:36 AM
Jigg's Avatar
Yes... truck running and 4hi button pressed.
sailors2
Dec 5, 2014 09:29 AM
red1127
Aug 1, 2014 12:31 PM
jspafford
Jun 10, 2009 04:51 PM
wick001
Dec 2, 2006 10:05 PM
tambo
Mar 4, 2005 05:44 PM
