4x4 vacuum
Old Feb 5, 2025 | 09:55 AM
Felcan's Avatar
Felcan is on a distinguished road
Default 4x4 vacuum
I changed the front brake lines on my 2005 blazer that is just used on property as a plow truck. I am not sure on what I have done but now have no front wheel drive . It is equipped with the 3 button system. When I put it in 4 high the light stays on and the actuator moves the cable maybe 1/4" . Looking at the vacuum hoses closest to the ABS module, I noticed the hoses in the picture....does this connect to a fitting that I cannot find....thanks
Old Feb 5, 2025 | 10:11 AM
LesMyer's Avatar
Yes, the fitting is on the vacuum reserve tank located inside the fender. Stand on your head to see it!
Old Feb 5, 2025 | 11:14 AM
Felcan's Avatar
I have looked all over for a nipple to attach the hose too but no luck
Old Feb 5, 2025 | 12:25 PM
Originally Posted by coolasice
The picture above shows where it should connect. The little red arrow link in the quote above will take you to the thread this came from with further illustrations of where the reservoir is.
Another good post from that thread:
Originally Posted by Captain Hook
The image in post #6 is taken from the center of the engine looking at the left inner fender. The part on the right is the ABS unit, and the part on the left is the cruise control module. It's possible that the plastic nipple is broken off flush with the vacuum reservoir, in which case, you won't feel it.
This image show the orientation of the reservoir, (the arrow points to the front of the vehicle):
Here is another view, (the arrow points to the front of the vehicle):
Old Feb 5, 2025 | 02:58 PM
Felcan's Avatar
finally found where the hose connects......needed a small mirror to guide me .......thanks to everyone that helped.....really appreciated it
frustrated jimmy
Dec 18, 2017 04:59 PM
SmileMore79
15
Jul 13, 2017 02:01 PM
dhud64
Feb 3, 2015 06:54 PM
DBone
Jan 21, 2012 08:21 PM
slyone1000
May 8, 2007 06:30 PM
