4x4 won't disengage
Old Jan 30, 2015 | 10:00 AM
Did you check pending codes in the BCM? Checking pending codes in the PCM will only show engine & transmission codes. Transfer case codes are stored in the BCM.
The scanner will list each module that it can access on the main menu screen: PCM, BCM, ABS, SIR, etc. Each module stores current, pending, & history codes, (3 seperate files in each module).
Old Jan 30, 2015 | 01:43 PM
wdhova's Avatar
wdhova is on a distinguished road
I got Codes!
In the order that they appear......
U1000 - Class 2 Data Link Malfunction
CO300 - Rear Pro Shaft Circuit Malfunction
CO374 - General System Malfunction
now what dot com
Old Jan 30, 2015 | 03:50 PM
LannyL81's Avatar
There are two threads here:
wdhova: Captain will need to respond to what those codes are all about.
bagherra: my suggestion to you is to remove the 4wd switch assembly from the dash, carefully disassembl the two halves and then re-flow all the solder joints using a soldering iron...not a GUN. Also clean the connector contacts at the TCCM module.
Old Jan 30, 2015 | 07:15 PM
Bagherra's Avatar
Bagherra is on a distinguished road
Lanny 81, cleaned the TCCM module connections today, no change. Will do switch tomorrow. Dumb question, difference between soldering iron and gun??
Was doing some checks when I got off work. Getting good vacuum at actuator under battery tray. Pulled the cable about 1/2". 4HI light still blinking. Can get into 4LO and I hear a noticeable thunk from transfer case and click from TCCM. Goes in 4LO but 4LO light blinks. When I put in 4HI, can hear TCCM click and click from transfer case, 4HI light blinks....4AUTO light just blinks too when in 4AUTO.
Also, HVAC works great, don't think vacuum is an issue. Any checks to do with the solenoid on the firewall?
Don't mean to threadjack, but I like it when stuff works likes its suppose to.
Thanks for u guys help!!! Anybody in or near Va Beach can lend a hand! Beer is on me!! LOL
Old Jan 30, 2015 | 07:29 PM
babydeuce's Avatar
babydeuce is on a distinguished road
In your case, my money is on a malfunctioning TCCM.
Old Jan 31, 2015 | 02:00 PM
wdhova's Avatar
Default Cleaning TCCM
Hey y'all, I did the cleaning today and everything seems to be working properly. Sprayed with connection cleaner and packed the fittings with the electric grease. There was obvious corrosion on some of the prongs. Now I got hope that helps with the wired codes I was getting.
Thanks again everyone, I love this forum, saves me so much money!
Old Jan 31, 2015 | 04:01 PM
You cleaned the connections at the TCCM?
Old Jan 31, 2015 | 07:51 PM
wdhova's Avatar
yep, the tccm. I am hoping this was causing my other codes.
Old Jan 31, 2015 | 08:48 PM
Bagherra's Avatar
guess i'mma get that grease tomorrow.
99blzr
Mar 12, 2018 11:54 PM
rvaughn622
Jul 4, 2010 06:01 PM
218persuader
23
Oct 9, 2009 07:24 AM
misfit
Jun 15, 2007 08:08 PM
GMdesigner
May 20, 2007 11:20 AM
