95 2wd blazer brakes
yesterday I pulled off the front rotors and worn out pads, I replaced the pads with a set of wagners and replaced the rotors with a new set. also while doing that I decided to replace the outer and inner wheel bearings and inner dust cap on the rotors. greased and assembled everything up and noticed this morning while test driving the truck that the breaks would grab on either side until i pressed down on the brake where the piston on the caliper would release. all the while the ABS light would stay on. I pulled the no. 18 fuse (brakes) which I assume is the abs fuse. and will test drive again shortly. any input would be appreciated.
well let me add that the no. 18 (brake) fuse should not be pulled because it keeps the transmission in first. secondly I used an OTC scan tool with abs diagnostic option and got these codes. 41 42 45 46 51 52 65 and 67
poertsch
Apr 23, 2016 01:05 PM
toms2000blazer
Jul 26, 2012 04:46 PM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
flamez2647
Jul 28, 2009 09:40 PM
