95 4.3 unknown vacuum hose
Old Jan 24, 2012 | 08:45 PM
1pickup's Avatar
1pickup is on a distinguished road
Default 95 4.3 unknown vacuum hose
1995 s10 blazer 4.3 vortec 4x4. while changing cap, rotor, etc., I noticed an open vacuum line pointing up towards the distributor. Followed it down & see it connects with several above transmission. Can anybody tell me what this is, & where this hooks to? I can't see any bung for it to go on. thanks
Old Jan 25, 2012 | 10:10 AM
spittybays
Guest
Posts: n/a
Is your 4x4 working? That sounds alot like were vac actuater line runs on mine and its the same spot that mine broke.
Old Jan 25, 2012 | 06:07 PM
1pickup's Avatar
I thought it was.
The thing stopped running & had to be towed home the other day. It started later, so I thought maybe cap was wet. It was loose, wires not great, one plug electrode was burned off. compression test was ok, except for #5 cyl @90lbs. Head gasket maybe, because I have lost some fluid. Intake gasket recently changed because of that, but it didn't help.
Can you tell me where that line goes to on the engine side? I can't see where it came from.
Old Jan 25, 2012 | 07:24 PM
spittybays
Guest
Posts: n/a
If its what Im thinking it comes up, strange, from under the battery tray. That's were the 4x4 vacum actuature is. Then it goes back to the firewall then kind of around the back of distrubutor then like down.
Old Jan 25, 2012 | 07:58 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
that is most likely your transmission vent hose. if its pointing towards the hood then thats probably what it is. at least i think that comes up around the distributor area. a picture would help also
Old Jan 25, 2012 | 08:12 PM
1pickup's Avatar
Vent hose was my next question. Looks like that must be it. Got it started w/ new tune up, & there is no vacuum on that hose, 4x4 is working. So, I guess I was worried about nothing. I'm too big to fit behind the engine, so I couldn't see where it was supposed to connect. It does have a rubber end on the hose that made me think it was supposed to go somewhere. The other end does go to the bunch of hoses above the transfer case. Thanks for the input. These forums are great & full of knowledge.
Old Jan 25, 2012 | 08:47 PM
yep no problem! never hesitate to ask
Old Apr 1, 2012 | 11:27 AM
breezicy's Avatar
breezicy is on a distinguished road
Wrong trans vent hose always close to trans under car/truck and always bigger then vacuum hose's
86TransAm
14
Dec 13, 2011 07:46 PM
rob1621
Apr 3, 2008 08:55 PM
dardamar
Dec 3, 2006 11:10 AM
fzr confused
Apr 1, 2006 03:06 AM
fzr confused
Mar 30, 2006 12:38 AM
