95 Blazer 4x4 Power Steering Leak
Old Apr 15, 2009 | 03:44 PM
SuperMuise's Avatar
SuperMuise is an unknown quantity at this point
Default 95 Blazer 4x4 Power Steering Leak
95 blazer 4 door 4x4 LT
Started leaking power steering during winter and it hasn't stopped. Today i wrestled with it for about 4 hours replacing the high pressure line (PowerSteering) and its still pissing fluid. Does anybody know what the problem is, or have the same problem? I would really appreciate it cause this thing is starting to get to my nerves!!
Thank you
Old Apr 16, 2009 | 03:57 PM
Where is it leaking from??? There are quite a few lines in the system.
Old Apr 16, 2009 | 05:43 PM
SuperMuise's Avatar
im not sure, its hard to say, but i believe the sketch you have up there isn't the same setup as mine. Its not the high pressure line cause i replaced it, so im wondering if you or who ever else has had this problem and figured out what the issue is...
Thanks
Old Apr 16, 2009 | 08:17 PM
It is possible that you do not have the power steering fluid cooler in front of the radiator, but everything else should be the same.
If you are certain that it is not the pressure line (the old orings did come out with the old lines correct?), then it is either the return line, the pump itself, or the steering gear box. Well, that is unless you have the cooler.
Old Apr 16, 2009 | 11:00 PM
SuperMuise's Avatar
obviously it could be any one of those steering components...
what im wondering is if anyone has had an issue like this, it is leaking like crazy... i have to fill the reservoir every week.... i know its one of the components.... im just wondering which one cause i really dont want to pull the whole damn thing appart
Old Apr 17, 2009 | 06:02 AM
Biohazed's Avatar
well thats what you are going to have to do eventually. Your best bet is to get yourself some de-greaser.. drop the skid pan and wash down the engine es the front were all the line are to get all the excess PS fluid off the engine then let it dry and then start it up and look for were the leak is. if your dropping a reservoir worth a week then you should be able to find the leak fairly easily once you get it cleaned up.
Old Apr 17, 2009 | 05:15 PM
SuperMuise's Avatar
thats probably what im going to have to do... After thinking about it im pretty sure its the second line (low pressure) where the reservoir connects. The steering box (after taking off that stupid plastic cover) isn't dripping so thats the only other possibility i can come up with.
drwsc6
Jan 19, 2011 10:39 PM
UberFail
Nov 12, 2010 10:20 PM
Zerbla96
Apr 25, 2010 11:35 PM
IROCZer
Jan 28, 2010 12:50 PM
dax44
Aug 31, 2008 08:00 PM
