95 Blazer LT, Some Plug is jumpered in my engine Bay? Pictures!
Old Jul 4, 2009 | 06:55 PM
libmotors408's Avatar
libmotors408 is on a distinguished road
Default 95 Blazer LT, Some Plug is jumpered in my engine Bay? Pictures!
Show Links!
Old Jul 5, 2009 | 04:21 AM
awe341's Avatar
awe341 is on a distinguished road
There is always the possibility that someone essentially hotwired the AC clutch to remain on rather than replacing the faulty control. Considering the location this is probably what this is. Usually any kind of jumpered wire like this is an attempt to bypass a faulty switch or other control and keep something turned on (or occasionally off)
Try disconnecting the jumpered wire and see if your AC clutch turns off.
Old Jul 5, 2009 | 02:41 PM
Check out the link below.
Old Jul 5, 2009 | 04:12 PM
That is your A/C low pressure switch. If the A/C system still works and cools properly with the jumper installed, then the switch is likely bad. I hope this is the case. If the system is run with too low of pressure, permanent damage to the compressor can occur.
Old Jul 5, 2009 | 05:23 PM
What you think?
Old Jul 5, 2009 | 05:34 PM
The low pressure switch is located in that big silver cylinder which is the filter/dryer. It can be swapped out without evacuating the system.
bertrenolds
Mar 27, 2011 11:04 PM
964x4ND
Nov 28, 2008 08:28 AM
djdrew010
Sep 4, 2008 07:30 PM
kiwiblazer
Apr 12, 2008 05:44 PM
boulonman
Mar 5, 2007 05:10 AM
