95 Blazer rough idle Middletown Ct
Old Jul 9, 2009 | 07:10 PM
  #91
paulggoo's Avatar
paulggoo is on a distinguished road
What is the part of the motor that gets the most stress?
PS it is not electronic.
Old Jul 9, 2009 | 07:14 PM
  #92
volfan4's Avatar
volfan4 is an unknown quantity at this point
i guess its the rings and he has low compression.
Old Jul 9, 2009 | 09:36 PM
  #93
1badblaze's Avatar
1badblaze is an unknown quantity at this point
My guess is crank bearings or tone rine for the crank sensor
I have the same problem on my 95 but it doesn't throw any codes and its
Very intermintent
Old Jul 10, 2009 | 04:04 PM
  #94
gscrippler's Avatar
gscrippler is an unknown quantity at this point
Well replaced the exhaust manifold gaskets, Flange dounuts and Muffler tail pipe to get rid of my exhaust leaks, With no luck problem still exist !!! Gonna try to get a hold of PaulGGoo. My guess to your question would be motor mounts??
Old Jul 10, 2009 | 04:49 PM
  #95
gscrippler's Avatar
do you think it's a bad piston??
Old Jul 10, 2009 | 08:43 PM
  #96
reelbroke2's Avatar
reelbroke2 is on a distinguished road
Im thinkin we have a similar problem..Maybe it's the color of our trucks Lmao!
Old Jul 10, 2009 | 09:07 PM
  #97
gscrippler's Avatar
Could be I'm trying to get in touch with the guy with the answers!!!
Old Jul 13, 2009 | 06:36 AM
  #98
gscrippler's Avatar
Some suggested that maybe I have bad valve springs what do you think?
Old Jul 13, 2009 | 04:04 PM
  #99
reelbroke2's Avatar
Yours could be a weak spring and i'm still thinking mine is a weak lifter..But wouldn't our symptoms show a leak down? I had mine tested several times and i have no leak down.
what a mystery.
Old Jul 13, 2009 | 09:03 PM
  #100
A weak spring could be caught by a leak down test, but probably would not. A weak spring can still provide enough seat pressure to seal, but not enough to keep the valve from floating (being thrown by the rocker arm) which can cause a misfire.
A bad lifter will not be caught by a leak down.
