95 Blazer rough idle Middletown Ct
Old Jul 22, 2009 | 07:00 PM
  #111
gscrippler's Avatar
gscrippler is an unknown quantity at this point
Talking
Update: It's been 2 days and my Blazer is still purring like a kitten !!!
Gee I thought i would get some kind of feed back on this long battle i had
Old Jul 23, 2009 | 09:06 PM
  #112
00bluegtp's Avatar
00bluegtp is on a distinguished road
So what exactly did you do please explain. I am glad you found the fix.
Old Jul 23, 2009 | 09:30 PM
  #113
reelbroke2's Avatar
reelbroke2 is on a distinguished road
LOL..start from page1 and read from the beginning, there's alot of info.
Old Jul 23, 2009 | 10:16 PM
  #114
gscrippler's Avatar
that's for sure, How you making out REELBROKE
Old Jul 27, 2009 | 06:48 PM
  #115
volfan4's Avatar
volfan4 is an unknown quantity at this point
so...you just tightened the rocker arm back to spec and the rough idle went away?
doesn't this mean the cam lobe is worn? just curious...
Old Jul 28, 2009 | 03:15 AM
  #116
paulggoo's Avatar
paulggoo is on a distinguished road
No, This means that the rocker arm or stud could have stretched. The stud that holds the rocker arm on could have pulled out of the head. Some studs are pressed in and some are screwed in.
The nut could have just loosened up a little bit.
Old Jul 28, 2009 | 09:37 PM
  #117
gscrippler's Avatar
what ever it was it's fixed now !!! been over a week and still running strong!!
Old Jul 28, 2009 | 09:48 PM
  #118
volfan4's Avatar
cool.. guess i might try pulling the valve covers this weekend and taking a look at mine.
Old Jul 29, 2009 | 05:58 AM
  #119
gscrippler's Avatar
I was doing a Cylinder leak down test and detected an exhaust valve leak, figured I had to get the head replaced because a seal was bad. When we put it back together and tighten the rocker arms back down then started it the misfire was gone so something was out of adjustment
Old Jul 30, 2009 | 10:40 PM
  #120
volfan4's Avatar
thanks for the info. keep us updated if the rough idle returns. i might just take off my valve cover this weekend and see if I have the same problem. If not...I think I might just go ahead and break down the engine. its getting annoying. I'm tired of replacing parts and no positive results. I thought it was a fuel or spark issue with the one cylinder(#6 plug was getting fuel fouled). I replaced regulator, spark plug wires, cap, rotor, and then the CPI spider with no long term results. Problem just keep coming back. I've found a reman engine locally for $1000 and plan on just going that route if this doesn't work.
Also, anyone who knows please answer, if what gscrippler did works on my truck, would it make since to replace the cam and lifters in a motor that has 160,000+ miles on it ?
