'95 Blazer Shakes while braking
Old Sep 6, 2009 | 06:45 PM
shmew22's Avatar
shmew22 is an unknown quantity at this point
Default '95 Blazer Shakes while braking
Alright, got a 1995 blazer that does some mean shakin when you brake goin over 35. Once you hit the brakes it keeps it up until you completely stop. Checked out the brakes and they seem to be fine. Is there anything i should check that would be causing this to happen?
Old Sep 6, 2009 | 06:55 PM
Biohazed's Avatar
I'll put money on warped rotors... take your rotors off and have them machined, or get some new rotors.
Old Sep 6, 2009 | 07:55 PM
thebigcheese109's Avatar
thebigcheese109 is on a distinguished road
I just had a problem with my 95 blazer's brakes. When I went out the driveway they would lock up and let go a few seconds later and be fine. Found out that the brake drum was out of round. Maybe you have a similar problem.
Old Sep 7, 2009 | 08:21 PM
g_mike's Avatar
g_mike is on a distinguished road
warped rotors or drums or could be tie rods.
what kind of rotors do you have? are they stock or slotted? if they are slotted sometimes you get a little shake....this would also happen if they are scored.
Old Sep 8, 2009 | 06:28 AM
awe341's Avatar
awe341 is on a distinguished road
Warped rotors are a common issue with these trucks if you get cheap replacements. Even more so if you get the cheap rotors and use a good set of pads with them. Replace the rotors and the pads as the pads will be unevenly worn and won't mate with the new rotors properly.
Do not wait long to get it fixed as that shake could cause a pad to break and cause you even more problems. Let us know if this does not fix the problem.
Old Sep 8, 2009 | 08:18 PM
shmew22's Avatar
Sorry for the late reply, comp issues. But yea, i replaced the rotors and pads about 3hours ago and it seems to have fixed the problem. Thanks for all the help guys.
trippymg
Feb 17, 2012 08:10 PM
hoffman_0283
Aug 30, 2010 04:55 PM
jesservargas
Jul 25, 2010 12:12 PM
chevy8jr
Jun 20, 2006 10:40 PM
Charidy
Aug 6, 2005 06:33 PM
