95 blazer spider injector install help
Old Oct 29, 2016 | 02:47 PM
pfc1's Avatar
pfc1 is on a distinguished road
Default 95 blazer spider injector install help
On my 95, does it matter which injector tube goes in which hole? I see that in 96 they tell you to label them on removal but nothing for 95. i can use the old spider for reference but i'm not sure if it was correct either, just want to make sure before re-assembly, thanks.
Paul
Old Oct 29, 2016 | 05:21 PM
Rusty Nuts's Avatar
Yes very much. Do enough research to be positive which injector goes into which hole.
Old Oct 29, 2016 | 07:39 PM
richphotos's Avatar
It depends on which engine you have in your 95.
If your engine looks like this
It does not matter which hole you put the injectors in.
The other style 4.3 engine, I am not sure.
Attached Thumbnails 95 blazer spider injector install help-10546d1355615257-identifying-4-3l-vortec-cmfi.jpg
Old Oct 30, 2016 | 06:54 PM
Graveyard's Avatar
Graveyard is on a distinguished road
I have a 96' model. I replaced my spider injector with a new ac delco from Rockauto.
It came with an instruction paper. But there is all kinds of info right here on this site.
I believe things changed from the 95 model to the 96 model so get more info before jumping in. I had never done the swap before and I relied on these guys to steer me straight and I'm confident in what I done due to the help I got here.
Good luck,
Later
Old Nov 13, 2016 | 12:15 PM
LannyL81's Avatar
It has been a long time since I did the spider in a '95, but from memory there is really only one way for each spider leg to fit, otherwise they are crossing and may not be long enough.
Again from memory, there are three legs on each side of the injector body and each leg goes into the corrosponding intake with no legs crossing.
How was the existing one connected?
Old Nov 14, 2016 | 07:33 PM
pfc1's Avatar
thanks Richphotos, i appreciate the info. I didn't believe that it mattered on the 95 vortec without the 6 pak under the plenum.
hunter05
35
May 16, 2024 09:01 PM
hunter05
Mar 29, 2014 11:32 AM
adriandear
Feb 10, 2014 03:41 PM
wjtaylor
Mar 29, 2012 06:03 PM
bigdaddykane93
Apr 7, 2010 10:26 AM
