95 blazer won't start
Old Mar 15, 2013 | 03:35 PM
rockp2's Avatar
Originally Posted by Captain Hook
Yup, 95 and older "W" engines have CMFI. It has one injector that is batch fired. It squirts fuel to all cylinders simultaneously each time any cylinder fires, (3 times per crankshaft revolution). Fuel pressure and leakdown specs are higher on 96 & newer CSFI systems because each injector is only fired once every two crankshaft revolutions. Their reason for increasing pressure is that CSFI injectors have a greater chance of plugging up from not squirting as often.
I can't wait to receive my "Hook School for Blazers" diploma to hang on the wall Thanks for the lesson.
Old Mar 15, 2013 | 06:03 PM
Welcome to the Blazer Forum School of Information, where tuition and diplomas are non-existant
Old Mar 16, 2013 | 04:02 PM
big-b's Avatar
big-b is on a distinguished road
I'm going to check the fuelk lines tomorrow, the only thing I can think is the rubber end that connects to the pump is somehow kinked. once I get that straight do you have any tips on how to check the ECM?
Old Mar 16, 2013 | 04:18 PM
The ECM has nothing to do with the excessive fuel pressure problem that you're experiencing.
Remove the return line, (5/16") at the rear of the intake manifold and attach a piece of rubber hose to the line that goes back to the tank. Remove the return line from the fuel pump module. Blow into the rubber line, there should be very little, if any, resistance.
andrewrj
May 6, 2012 07:28 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
