'95 with cpi
Old 08-19-2005 | 06:37 PM
sdime ryder's Avatar
sdime ryder is an unknown quantity at this point
Default '95 with cpi
i need some help my truck will not start i have replaced everything from the fuel pump to the injectors and everything in between i have spark and fuel. any help ideas would be great
Old 08-21-2005 | 10:49 AM
Phatboy's Avatar
Phatboy is an unknown quantity at this point
Default RE: '95 with cpi
I have a '93 S-blazer with a 4.3 W motor. Check the magnet in the "polepeice" or "shaft" for the distributor, mine was cracked in a couple of places causing a "North and South effect for the pick up coil. Engine would start barely. Not bad replacing but diagnosing was a bitch. Good luck.
Paul
'93 S-Blazer 4.3 "W"
Old 08-23-2005 | 01:04 PM
Hanr3's Avatar
Test your crank position sensor and ignition control module. Pull a plug wire, any one will do. Take out the spark plug and stick it back into the plug wire. Now pull the coil to distriburator wire at the coil end. Hook the spark plug wire with the plug in it, into the coil. Put the plug next to the exhaust manifold (use insulated pliers to hold plug wire) and have someone crank the engine. If no spark, pull the Ignition control module and take it to your favorite autoparts store for testing. Call first, AZ didn't have a harness for my 2000. If the ignition control module checks out good, then its your crank position sensor. Its located by the harmonic balancer.
Make sure you have plenty of grease between the ignition control module and the plate it attaches too. The grease dissapates heat, without it you'll fry your IGM in no time.
Edited to add this.
You could have spark even if the IGM or Crank position sensor are bad. However it won't be controlled, timed correctly.
prbjeepin
04-08-2013 10:14 PM
93LT
45
11-13-2010 06:13 PM
NC93BLAZERLT
16
01-04-2010 11:08 AM
Rosetta
10-14-2005 02:21 PM
BUDWZR8
08-21-2005 10:31 AM
Quick Reply: '95 with cpi
