95 jimmy engine swap need help!!!!!!!!!
Old Sep 22, 2010 | 06:57 PM
rob03's Avatar
rob03 is on a distinguished road
Default 95 jimmy engine swap need help!!!!!!!!!
my jimmy has a 4.3 vortec can anyone tell me if a 4.3 vortec out of a 95 chev half ton will work
Old Sep 22, 2010 | 09:12 PM
mr.vls's Avatar
If it is the Same VIN code (W or Z) should work just fine just use your TBI unit. To be safe treat it like a long block and swap over all your existing Intake system and accessories.
Old Sep 23, 2010 | 12:10 AM
old skool luvr's Avatar
that's kinda not nessasary.
there isn't any "Z" code in the 2nd gen trucks. but he is right, so long as the 8th digit is the same, it souldn't be a problem. but like he mentioned, you're more than likely going to need to change over all of your drive accessories on the front-including the brackets.
Old Sep 23, 2010 | 03:09 PM
rob03's Avatar
Default will i have any problems?
This motor comes complete(basicly everything was unpluged from the truck and pulled out with the motor.) with wireing harness,computer under the hood fuse pannel,starter and altinator, manifolds .. the only thing that looks different is the fuel injection set up. my 1st 4x4 dnt kno much about them.
Old Sep 23, 2010 | 03:28 PM
rriddle3's Avatar
*Moving to '2nd Gen Tech'. Please pay attention to what section you post in*
Old Sep 23, 2010 | 11:36 PM
oh, so the p/u's engine is a Z code (TBI) then, not a W code (CPI) like in your truck.
looks like you've got an issue on your hands. the only way you're gonna have that new engine run in your Blazer, is to swap the top end from each engine.
that means you need to remove the heads & intake from your Blazer's engine, and swap it with what is on the "new" engine. which is quite a bit of work, for a used engine.
and no, you can't just swap the intake systems. the head-to-intake angles are different between the Z code & W code engines.
mind telling us why you're changing the engine in your truck?
Old Sep 24, 2010 | 03:34 PM
rob03's Avatar
i smell gas really bad and theres white smoke comming out of the exhaust and she runs ruff
Old Sep 24, 2010 | 03:35 PM
rob03's Avatar
can i use the whole engine if i change the wire harnest and fuse boxes
chevylover23
Jan 4, 2014 06:17 PM
Jimmy man 4x4
Engine & Internal
Apr 4, 2012 08:50 PM
Mrfixit1599
Jan 16, 2012 02:05 PM
young_hunter05
Nov 10, 2010 05:28 PM
LowLife
Jan 24, 2010 11:57 AM
