95 jimmy no spark
95 jimmy no spark
i have a 95 jimmy that was hard starting and now it died
it has the early horizontal tower dist.
i checked the spark and it looked weak at the plug wires
i replaced the coil and now i have no spark
cked all fuses-ok
i have power at the coil
can get no pulse at coil when when cranking
so i changed the distributor/mod
and i still have the same problem
still no spark
the distrib gears were shot on the old one
so it needed it anyway.. so i'm not that upset
this truck has givin me so many good miles so it needs to be fed
every now and then.. lol
what would be my next thing to check?
am i looking at the crank sensor being bad?
how do i check that?
and how hard is it to change that sensor if it is bad?
do i have to take the crank pully off
to get to it?
thanks for any help or direction
cked all fuses-ok
still no spark
to get to it?
If you dont have spark then i would suspect a faulty crank sensor... do you have a check engine light on?
no check engine light on
i'm looking how buried that sensor is
i'm wondering if that pully has to come off or not?
not sure on a 95, most likey you can remove the sensor by removing a hold down bolt, but poke your head around the crank pully and if you can see the sensor you most likley can take out the hold down bolt and pull it out. it should be a 3 wire connector
ok this is getting really weird
i went and looked real good
my crankshaft sensor is missing????
it looks like it was gone for a while
i can take a pic
how could it of run like this?
i cant find any wires that go to it
i have a new sensor and i see exactly how it
fits into the side of the timing cover and the bolt and sensor are gone???
no wires or plug in sight??
this makes no sense and now i dont know what the h to do???
i will have to look for the plug somewhere?????
i can take a pic
if their is a hole their should be wires somwhere down there.... a pic wouldnt hurt...
Keep looking and see what you find. you might have to jack the front of the vehicle up and crawl under it to see the connector (or whats left of it)
riddle me this
now i would assume the sensor would go in this hole?
the first pic is what i first saw
and i was wondering why i couldn't figure out where
this thing went
this thing went
i have no idea where the wires are
or the plug even???
this truck is kickin my ^$%$ now!!! lol
it has 286k and ran great and if i can figure this out
maybe a few miles more.
i can't believe it ran with this thing totally gone like that??
whats up with that??
this really has me perplexed it could be missing??????
i poked in the hole and it was solid??
and i don't see and wires anywhere to be found???
or the plug even???
i went back and really looked for a plug and can't find one anywhere?
also does anyone know the bolt size for this?
if i try to do
what i have no clue about?
i just cant believe this thing is missing
if i try to do
i don't have a cam sensor in the distrib
and it seems like i don't have a crank sensor either???
i'm starting to think maybe its a fuseable link
or ignition switch.
what makes it confusing is i have an earlier truck and
it seems not to have these things that newer trucks seem to have??
and even the testing procedures are hard to figure out for me...
or ignition switch.
