95 no spark no start
Old Mar 1, 2011 | 11:40 AM
ccrage2005@aol.com's Avatar
ccrage2005@aol.com is on a distinguished road
Default 95 no spark no start
Ok...I have 4.3l 95 v6. Starter went out and I replaced it, also replaced fuel lines in plenum. Noticed we were getting some spark to plugs every now and then. So got New rotor, cap, wires, distributor, coil... Getting spark into distributor from coil but nothing coming out to plugs. Checked ohms on cap, rotor and wires all look good. There is about 12.3 volts going to coil and it drops a little during cranking. The spark looks a little weak off the coil though, so got another new coil and still that same spark. ICM is good due to coil firing... Anyone???
Old Mar 1, 2011 | 12:16 PM
CO Chevy Dude's Avatar
CO Chevy Dude is on a distinguished road
Is the dist. turning when you crank the engine? If you've got spark going to the cap and none out, you could have a bad timing set or broken drive gear. Did you get the dist. timed correctly?
Old Mar 2, 2011 | 05:20 PM
Rotor turns just fine, timed the truck about five or more times using compression method and straw. When I first put new distribute in I was getting spark at the plugs but getting little backfires inside plenum, figured I timed it wrong which I did. So friend came over and retimed it and ever since no spark coming out distributor. There is spark coming in but a little weak. Thought maybe crankshaft sensor or has to be something I am missing??? Doesn't make sense. I even had a tech from dealership stop by for a few minutes and he couldn't explain it.
Old May 12, 2011 | 03:44 PM
waviaerith's Avatar
waviaerith is on a distinguished road
Any new results with this issue? I'd really like to know, thx!
JavierEscalonJr
Oct 14, 2020 11:38 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
fast400
Aug 31, 2007 05:07 PM
