Heating Issue
Old Jan 12, 2011 | 05:05 PM
waviaerith's Avatar
waviaerith is on a distinguished road
Exclamation Heating Issue
About two months ago I was having an issue with leaking coolant. I replaced the heater core and the problem was fixed; no more leaking coolant. After replacing the heater core I noticed that I wasn't able to adjust the heat very much. On my coolest settings I would have warm air, and on the highest setting I would have very hot air. I have not changed anything but now on my lowest settings I have very cold (colder than my AC) air and on my highest settings I may get luke warm air. I noticed that the air will start to get closer to luke warm as my engine heats up, but once I hit normal temp (about 210-215 degrees) the air turns to extremely cold... I also hear this odd "sloshing" noise. It will happen while I'm driving, parked, or if you rock the vehicle side to side. And lastly I am once again losing coolant. I haven't lost any for two months until now (the sloshing noise has also gotten worse)
Has anyone else had this issue? or something simular?
Thank you
Old Jan 12, 2011 | 05:54 PM
warthogdriver's Avatar
you have air trapped in your cooling system.
do a search for the fix, details
basically what i do is run from cold start and throttle and slowly ad coolant, till no bubbles. thats just me.
Old Jan 13, 2011 | 10:12 PM
waviaerith's Avatar
Thanks for the tip, I'll try and do that this weekend and update with results. Quick question when you had air in your system did it affect the temperature as well?
Old Jan 13, 2011 | 10:51 PM
yes, the air pockets affected the heat, also the antifreeze to water ration might be off.
Old May 12, 2011 | 03:28 PM
waviaerith's Avatar
I thought I had replied to this a long time ago, but apparently not.
so I did what you said and got air out of the system which gave me back warmer heat and got rid of the 'gurgling' sound. However a few weeks later it was back again. very frustrating...
Old May 12, 2011 | 03:45 PM
You probably still have air in the system or the system isn't completely sealed.
Mullet_Night
Feb 8, 2013 10:40 AM
blazergirl84
Nov 28, 2012 03:08 PM
Manheim
Jan 29, 2012 12:04 AM
pctechdude
Oct 13, 2010 08:56 AM
jagblazer01
Oct 16, 2009 06:57 PM
