95 s10 blazer driveability problem
Old Jan 25, 2014 | 05:29 PM
RMBlazernut's Avatar
RMBlazernut is on a distinguished road
fuel filter is not leaking..how do i test for the pump in the tank.
Rick
Old Jan 25, 2014 | 10:28 PM
cleburne red's Avatar
Not that the fuel filter is leaking, you need to test the pressure at either the fuel filter, or at the pump itself.
If it's leaking down, it could be one of two places; either the regulator in the manifold, or the pump itself could be not holding pressure.
Testing at the filter or pump removes the regulator from the equation. The pressure tester should be hooked up in such a way that all the fuel flow stops at the tester. With the key on, this should give a reading of about 80 psi or so. If it holds pressure in this configuration, the pump is good, and the the problem is in the manifold. If it drops pressure like this, the pump is the problem.
You might need to run to home depot or similar and pick up a fitting or two to adapt the tester to the fuel filter or the pump. The ones I've rented didn't have anything to connect to either.
Old Jan 26, 2014 | 05:38 AM
OK I understand now..that was throwing me for a minute..this blazer is on hold until spring..I live where we get lots of snow and this year its been really cold and. not laying in the snow to do this test..lol I do have a backup blazed to drive until then..When. startup again I will post my results..thank you all so much form your help..you game me direction on where to go.
Rick
Old Jan 26, 2014 | 09:11 AM
No problem! It's good you have a back up, I wouldn't want to lay in snow, either!
Old Jan 26, 2014 | 02:55 PM
Sometime next May or June, when the snow is almost gone, pick up one of these: Buy Needa Parts Steel Fuel Line Repair Kit - 3/8" x 4" with 16mm Clip 800-170 at Advance Auto Parts= It will connect to the forward end of the fuel filter, (outlet). Attach a piece of 3/8" fuel injection rated rubber fuel line to the adapter. From there you'll need to do some "creative plumbing" to connect the line to your tester.
Old Jan 27, 2014 | 10:13 AM
If I get a day above 32 degrees I will perform this check I got the adaptors to do it yesterday
Rick
Old Jan 30, 2014 | 07:33 AM
nitetrucker's Avatar
nitetrucker is on a distinguished road
I have a 95 blaze also just had to do a FPR and nut kit on mine. took longer than expected cuz my hand went numb from cold but not that hard
Old Feb 13, 2014 | 06:52 AM
Ok got to do the test..it hold 61 pounds of pressure before the fuel filter for over 10 minutes
Rick
Old Feb 13, 2014 | 10:46 AM
spittybays
Guest
Posts: n/a
There's nothing I hate worse then I truly inconclusive test. Tell me the exact method you used to test this.
The proper opening of that regulator is exactly 61lbs.
Coincidence scares me. If the pump is actually running at 61 psi its failing.
Old Feb 13, 2014 | 12:10 PM
I took the line off the fuel filter where it goes into the filter. I then used adaptor to screw onto the line.I hooked the line up to my fuel pressure tester. Cycled the key.guage went to 61 pounds and held there..when I hook it up to the port by the regulator it goes to 61 pounds then falls to 0 in 3 minutes.
Rick
