95 S10LT 4.3 starts then dies
Old Nov 8, 2010 | 03:07 PM
slinger73's Avatar
slinger73 is on a distinguished road
Default 95 S10LT 4.3 starts then dies
I recently got a p0440 code and was able to find a fix the problem. It entailed dropping the fuel tank and checking the seals and connecting hoses. Once finding the leak(damaged hose) the code cleared. Now the truck will start and run about 1-5 min before dying. As it was running I could hear the fuel pump working, replaced one year ago, and then it sounded like it started to loose pressure and the engine died. I have been searching the thread and know that I need to check the pressure with a gauge. I would like to know what else to trouble shoot and if anyone has had similar problems and what the most likely fix is. This is a 2nd gen engine with a w in the vin.
Old Nov 9, 2010 | 09:04 AM
cage47's Avatar
cage47 is on a distinguished road
Two things jump to mind. First, the fuel filter. And second the iac valve.
Old Nov 10, 2010 | 03:22 PM
slinger73's Avatar
Thanks for the info. I'll be sure to check those put also.
reddheadnla
Apr 23, 2011 11:08 AM
sk8_dude90
Nov 30, 2010 02:25 AM
Blazer Will
Dec 13, 2009 06:22 PM
TTATE
Aug 11, 2009 07:43 PM
mafiaboy01
Aug 5, 2009 06:29 AM
