1993 blazer 4x4 starts runs for about 30 seconds then dies. HELP PLEASE!
Old Apr 23, 2011 | 06:35 AM
reddheadnla's Avatar
reddheadnla is on a distinguished road
Default 1993 blazer 4x4 starts runs for about 30 seconds then dies. HELP PLEASE!
I have a 1993 s10 blazer that will crank up and run for about 30 seconds or so then just die out. I installed a new fuel pump about a month ago and a new fuel filter and it ran descent but i have no clue what it could be. I put in an airtek fuel pump could it be bad already? Thanks for your help.
Old Apr 23, 2011 | 10:06 AM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Yup. Rent the fuel pressure tester from your local autoparts place. What is the pressure KOEO (key on, engine off)? What is the pressure 10 minutes later?
Old Apr 23, 2011 | 11:08 AM
Cidium's Avatar
Cidium is on a distinguished road
If you need to replace the pump I suggest using an ACdelco. I got mine off EBay and it was reasonably priced.
ShanoMac87
Nov 18, 2020 11:10 AM
bluhming
Jul 9, 2015 01:01 AM
SteveBessert
Aug 7, 2014 04:29 AM
mafiaboy01
Aug 5, 2009 06:29 AM
