95 wont start
Old Nov 26, 2010 | 08:33 PM
kidsblazer's Avatar
kidsblazer is on a distinguished road
Default 95 wont start
My sons 95 blazer turns over but wont start. He had the problem thanksgiving morning. I went to his house and thought he had just run out of gas. I put two gallons in and it started right up. He said it did it one other time but started eventually. He did not have any other problems starting it about 5 more times. However tonite it wont start. I filled the tank so I know it is full. I tried it and it sounds like it isnt getting fuel...but could it be a spark problem...coil? Any way to test the fuel pump, or is there an inline filter? Ill take it to the shop on monday but if there are some easy fixes im all ears.
Thanks
Old Nov 27, 2010 | 11:52 AM
Edelbroke's Avatar
Edelbroke is on a distinguished road
I've just been through this with mine. I would say the first thing to check is the fuel pressure. There is a sticky on the main page on the procedure. That will tell you quite a bit. Good luck.
Old Nov 28, 2010 | 11:59 AM
kidsblazer's Avatar
Thanks, after I wrote I found the sticky. Had fuel pressure just minimal. Pulled the fuel filter...plugged. Replaced, took awhile to get it started but everything is ok now. SO FAR! Thanks for the info.
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
slammed95blazer
Oct 27, 2010 07:24 AM
jetsmy
Aug 1, 2008 10:10 PM
