96 4.3 wont start
O.K you smart guys, here it goes. I have a buddy check the fuel pressure. It holding steady at 55-60.I have spark at the plugs/coil etc. I tried starting fluid and nothing helped. It pulled a mass air flow code, but I think it did so becouse I unhooked it when I tried to start it. I cleaned the egr and maf. I also changed the fuel filter. I am leaning towards pulling that plastic cover off the intake and looking at the fuel pressure regulator. Am I on track or do I need to check anything else ? By the way, after several cranks I can smell gas. I also turn the key to let the pump prime prior to starting or turning the engine over. Any input would be greatly appreciated.
Have a similar problem going on. Working on a 96 Blazer for a buddy. He picked it up from a police auction. Looks like its been sitting for roughly 3 years. Fuel pump was dead so I replaced it. Will run off starting fluid or a little gas dumped in intake. Fuel pressure around 65psi. But won't run on its own.
You said you checked fuel pressure and it was at 60 psi and holding,Dont waste your time pulling the upper intake to check your regulator because you already checked it with the fuel pressure test. Check your crankshaft position sensor,camshaft position sensor.Did you check to see if there are any codes? If you have spark and fuel and good pressure one or the other sensors are bad and it should set a code even if it does not start. By the way do not try to start it without the mass air sensor hooked up because it not start and you could be shooting yourself in the foot. Hope this helps.
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
slammed95blazer
Oct 27, 2010 07:24 AM
jetsmy
Aug 1, 2008 10:10 PM
