96 Blazer 4.3L
Old Sep 13, 2015 | 02:00 PM
William H Bonney's Avatar
William H Bonney is on a distinguished road
Default 96 Blazer 4.3L
96 Blazer 4.3L 4DR/4WD
Air compressor is locked up, air hasn't worked in years anyway, so I just want to bypass the compressor.
Does anyone know what size belt (part # / brand) this belt would be, if I'm not removing the compressor and adding a bypass pulley?
Any help is appreciated.
Thanks in advance.
Old Sep 13, 2015 | 04:38 PM
rriddle3's Avatar
Read this thread:
https://blazerforum.com/forum/2nd-ge...ne-belt-41726/
Also, you tend to get more interest and help if you title your threads with something that lets members know what the thread concerns.
Old Sep 13, 2015 | 05:49 PM
perumotors1369's Avatar
perumotors1369 is on a distinguished road
google this..Dorman 34275..Jerry
Old Sep 14, 2015 | 08:18 AM
Fuel sending unit ?
Old Sep 15, 2015 | 04:33 AM
I'm sorry-my bad..wrong number...Dorman 34175..try that..Jerry
Old Sep 15, 2015 | 09:26 AM
Thanks for all the help guys!
Old Sep 19, 2015 | 10:27 AM
Still having a heck of a time locating the correct sized belt for this. I have installed the bypass pulley, however the non-AC is way too small and the AC belt is way too big!
Old Sep 21, 2015 | 05:48 AM
that's strange..whenever I have used the by pass pulley the existing belt worked..if the pulley diameter is the same then it should work with your old belt..I'd check out the pulley diameter and go from there...good luck. Jerry
Old Sep 21, 2015 | 01:18 PM
BlazinClint's Avatar
BlazinClint is on a distinguished road
Howdy!
Probably won't help now that you installed the bypass pulley, but I had my compressor lock up last year and I'm driving with the compressor in place, but electrical connectors disconnected and ac clutch (plate?) removed. This allows me to keep driving with the ac system sealed until replaced/repaired properly, and can still use heat/vent. Here's a link to the thread I posted:
https://blazerforum.com/forum/2nd-ge...c-w-4wd-87461/
