96 blazer
Old Mar 12, 2005 | 10:23 AM
wheid570's Avatar
wheid570 is an unknown quantity at this point
Default 96 blazer
stalled at a stop sign yesterday fuel filter just changed new spark plugs air filter seems to be getting too much air when the gas is quickly snapped
Old Mar 13, 2005 | 11:57 AM
wheid570's Avatar
Default RE: 96 blazer
does anyone have any info about this problem i put some fuel injector cleaner and gas tank treatment in it yesterday seems to be a little better but i think the problem is still there any advice from anyone would be greatly appreciated
Old Mar 13, 2005 | 04:40 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
do you have a check engine light?
Old Mar 13, 2005 | 07:14 PM
wheid570's Avatar
no i have no check engine light i read in some other threads that you could have autozone check that for free wich is great news but i havent one to check dont know what it is ive checked all over for vacumm leaks dont have stethoscope though a guy at autozone told me that there have been alot of reports of bad gas i thought about putting 92 octain in from now on but who can afford that
Old Mar 13, 2005 | 09:32 PM
zero psi's Avatar
Retired Admin
to help check for vacum leaks, get a can of carb cleaner and squirt it on vacum lines, around the base of the intake, and around the base throttle body. if the idle changes, then there is a leak. it could also just be bad gas. or the fuel pump may be going. anything else i can think of would set off a light.
