96 Blazer 4L60e problem
Old May 10, 2010 | 04:51 PM
yeepman2's Avatar
yeepman2 is an unknown quantity at this point
Default 96 Blazer 4L60e problem
I have a 96 Blazer 4x4 with a 4L60E. I put a new motor in it 30k miles ago.
I am having a trouble at speeds over 60 mph. I'll be driving along and it feels like a surge kinda. its intermittent and when it happens the tach jumps up a bout 200 rpms. I've been told it maybe a torque converter lockup problem. I took it to shucks and read the codes, but nothing. I;m not sure if there reader does transmission codes. Any help would be greatly appreciated.
Mike
Old May 10, 2010 | 06:41 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
it sounds like a slip to me. is the check engine light on?
Old May 10, 2010 | 06:52 PM
yeepman2's Avatar
It might be a slip,but its very quick and it doesn't happen under load. No check engine light, no codes with a obd2 code reader at shucks. I'm not sure if it could ready tranny codes.
Old May 10, 2010 | 08:09 PM
200RPM just happens to be the approximate slip speed of the torque converter. Sounds like something is happening with your TCC circuit. It could be a wiring problem either outside or inside the transmission, or a TCC solenoid issue.
Old May 10, 2010 | 09:14 PM
yeepman2's Avatar
it happens around 2000-2300 rpm. amy way to test it?
dj00140
22
Nov 4, 2015 05:03 AM
an240172
Sep 7, 2009 02:58 AM
dksob81
Jan 30, 2009 06:33 AM
doubleuap
Nov 10, 2008 12:34 PM
95blazer8620
Oct 19, 2007 01:26 PM
