96 Blazer ABS Code C1281...Please Help!!
Old Nov 25, 2007 | 08:21 AM
tom04841's Avatar
tom04841 is an unknown quantity at this point
Default 96 Blazer ABS Code C1281...Please Help!!
I have a 96 Blazer and keep throwing a abs c1281 code. The abs light comes on around 15mph and stays on until i get below 15mph. How do I fix this?
Old Nov 29, 2007 | 06:03 AM
tom04841's Avatar
Default RE: 96 Blazer ABS Code C1281...Please Help!!
No one has a clue?
Old Nov 29, 2007 | 08:00 AM
When I looked for this code I came up with a lot of different applications. ABS codes are specific to the ABS unit used and GM varied the ABS units across its product lines so this code may mean something different depending on the application.
I suggest you go to OBDII.com and put in your code, then find the trouble code description that matches your VIN, specifically you will need the 2nd, 3rd, 4th, and 10th digit of your VIN. Can't diagnose further without the trouble code defined and since it requires some more information on your truck... The ball is in your court.
barryellen81
Jun 24, 2013 08:36 AM
Tinted
Mar 15, 2012 02:56 PM
Cidium
Apr 27, 2011 07:16 PM
98blazr
44
Aug 21, 2009 01:17 AM
rogggg1020
Nov 11, 2008 08:05 AM
