-   -   96 Blazer ABS Questions (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/96-blazer-abs-questions-96060/)
huck Jan 9, 2018 01:32 PM
Originally Posted by jone531@bellsouth.net (Post 684932)
Just thought of this...You can try shooting an email to Rockauto to see if they can get one. I had to do that with a hard to find harmonic balancer once for a different vehicle. They found it no problem..
There's also www.lkqonline.com as well who can supply used parts.
https://www.lkqonline.com/1996/Chevr...k-Brake-Parts/
Thanks. I just verified that brake assembly is what I need. What I was told is that the module is part of the pump assembly.
On most of the used auto parts web sites, you get a choice of anti-lock brake computer or anti-lock brake assembly. It seems the right choice is the assembly. Seems backwards to me, but when you select computer it comes back with chassis control box.
huck Jan 12, 2018 12:59 PM
I got a used ABS Assembly and put it in. Now both the ABS light and the Brake (parking) light are on.
I took it for a short drive to see if computer would reset. The first few times I hit the brakes, the ABS didn't seem to work as the wheels locked up. Then the brakes started working fine. When I jammed on the brakes, the wheels didn't lock up which seems like the abs was working.
A couple of questions:
  • Do the brakes need to be bled after replacing the ABS Assembly?
  • Is it possible (probable) the computer will reset and the problem is really fixed?
Thanks
huck Jan 28, 2018 12:28 PM
Still need help. Here's an update.
I read that the parking brake problem was usually hydraulic problem, and sure enough, one of the brake line connections to the control module was loose. I tightened it, but light stayed on. Finally was able to get someone to bleed system and light went off. Unfortunately, 5 miles later it came back on. So now, ABS and parking brake lights are both on.
I asked mechanic to check the EBCM ground because I had been unable to find it. He insisted there wasn't a separate ground that it just connected to the ground for the car. I told him I had read it was either on the radiator mount or under the drivers door, but I couldn't find it at either location. He again insisted it didn't have a separate ground. Does it?
I also told him that the Blazer made a loud thump when I turned hard to the right. It appeared to be from the front passenger side, so I jacked up the Blazer and took off the tire. Everything was covered with grease. I suspected the axle, but that is beyond my knowledge and ability to tackle. I asked mechanic if the grease might be causing the wheel sensor not to work. He said no. I found that strange as many sensor problems appear to be from dirt getting into the sensor. What do you think?
Again, here's my questions:
  • Parking light went off after bleeding brakes, but came back on after 5 miles. What could cause that to happen?
  • Does the EBCM have it's own separate ground?
  • Could grease leaking from the axle cause the wheel sensor to not work?
Thanks
Mike.308 Jan 31, 2018 05:38 PM
Thanks
  • ad 1. I didn't went through that issue, have no idea. Maybe one of Your ABS sensors has a damaged wire and while bleeding You accidentally moved the wire to a working position...?
  • ad 2. No idea, but still if You got the wiring diagram and a continuity tester You can measure ground connection Yourself.
  • ad 3. No. Hub has a rubber sealing there, so no dust/grease can get inside. But of Your axle shoe is busted, my advise - better have it done.
Cheers, Mike
