96 blazer gas smell
Got a 96 blazer with a gas smell. I changed the spider unit today and still have a gas smell. No visible gas on the lines. Not sure where to go next any suggestions.
i also have a gas smell but my check valve on top of the gas tank cracked somehow.. so i would check that.
This is a shot in the dark but i think there is a fuel vapor canister under the rear next to the filler neck.. i would check that as well
![Icon Shrug](https://blazerforum.com/forum/images/smilies/icon_shrug.gif)
My smell seems to be coming from under the hood, when your check valve went was there a strong odor coming from the rear because i don't have the odor in the cab the strongest gas smell is driver front. Also there is no pressure when the blazer is off and I have read this may be the check valve. Is pulling the tank the only way to check the valve?
I think I found the prob. Got a fuel leak coming over the oil pan think it is the line. Any suggestions for this?
mike6sic6
10-21-2010 05:43 PM
Cobra102000
07-04-2010 08:08 PM
chrisblaze
05-23-2009 02:21 PM
sunoco
04-03-2008 10:51 AM
